Solving rising damp
21 Dec 2012
Dear all,
I have a very localised area of possible rising damp next to my front door. On the inside wall, the plaster is crumbling off a little. Does anyone have any DIY recommendations for how to fix this. It's an old (150 yrs) house and so may not have a traditional damp course (i can't see one). Are there any products worth using?
Thanks for any help
Steve
more accurately, you have very localised area of damp next to your front door.
Is it a solid floor?
Is it between the place where the outside stopcock used to be, and where the kitchen sink used to be?
How is rainwater kept away from the door and frame?
Where is the nearest radiator or other pipework?
Post some photos.
If it doesn't have any DPC, it won't suddenly need one after 150 years without.
If you are looking for some inject into the wall stuff or miracle paint / render etc. - then no.
They are all a massive waste of money and will do nothing.
Dealing with damp is very simple.
1. Identify where the moisture is coming from.
2. Remove the source of moisture.
Thanks for the responses. John D, it is a solid floor (concrete or something similar). As far as I know, the kitchen was never near there and nor was there or is there an outside stop cock there. Rainwater is kept away from the door frame by guttering, which is quite new and does not leak so far as I can tell. There is no plumbing in the entrance hall where the door is located. I should have been more accurate with the description. It is not immediately next to the door but about a yard to the right. The plaster is crumbling just above the skirting board and the problem reduces the higher you look such that there is no evidence of crumbling plaster once one gets to more than 18 inches from the floor. I'm at work at the moment so can't post photos now but hopefully that clarifies things somewhat.
no, but the water supply pipe often runs under the hall floor on its way to the original position of the kitchen. After 60 to 100 years, old pipes often leak, so it would not be unusual.
