I'm under way with my ground level cedar decking project but would be grateful of any help with the following questions:
1. Deck size is 3m x 3m, with joists at 45 deg. I have a little bit of timber left so would it be worth putting some noggins in?
2. The deck is to be attached to the wall and I was thinking about supporting the frame at 1.5 metre centres, with perhaps a support in the middle for the centre joist. I am using 6 x 2 timber. I will do a bounce test but I know some people suggest greater support - any recommendations (particularly do I need to add more support for some of the joists)?
3. I will probably be using around 250 stainless steel screws. I was wondering whether it would be worth cutting some plugs to hide the screw heads. Will be pretty time consuming but would it be worth it?
4. Finally, I would as much as possible like to keep the fairly new timber look to the deck. I have seen reference to products such as Seasonite and Textrol but are these any good for want I want or are there any other good products for cedar.
Any advice or information would be much appreciated.
Many thanks,
Damian
Many thanks,
Damian
