Hi there
We are in the process of designing our garden office come gym come extra bedroom for when the family stay...
It's going to be a 6.6mx5.8 x 2.5m high timber frame building, flat roof, boarded in OSB on the walls and roof, suspended timber floor, and then covered in shiplap cladding.
It's going to be used quite a bit as a gym/study and also as a bedroom (sofa bed) if family are round. So needs to be warm, but it's not being lived in 24/7...
I keep going round and round in circles with regards the insulation. I want to keep costs down as much as possible and the biggest expense is the insulation.
Question 1 - floor insulation
I've decided to use EPS70 75mm polystyrene for the insulation for the floor - nice and cheap at around £165 for 38m2 and think this should suffice. Does this sound okay?
Question 2 - roof insulation
It's going to be a flat roof. I'm thinking of going for a warm roof construction with an EPDM membrane straight on top of the PIR boards. What is the minimum depth I can get away with to keep costs down? Its 38m2 so I need around 13 boards and want it cheap as poss but still thermally good!
Question 3 - wall insulation
It's going to be boarded OSB outside and then clad and internally plasterboarded. Again - what depth insulation should I be shooting for to make it 'good enough' for the use described? It's going to be 4x2 walls so the cavity can take anything up to 100mm but theres around 54m2 of insulation (about 19 boards) needed which very quickly adds up...
Any help, opinions etc are greatly appreciated!
Cheers
Matt
Cheers
Matt
