Hi
I'm having some 'major' work done on my 1902 built house including a double storey extension. Significant parts of the original supporting walls have been removed and steels put in. (and more of the same to come)
All calcs were done by a structural engineer and going by past experience he always over specs things. Parts of the original walls, which would become piers to support steels, were underpinned with 1m x1m x 1m concrete pads.
I watched all the steels go in and temporary support was provided, they were well packed in, steel plates used etc.
However it seems as though there has been some movement of the building at the rear (where most of the existing rear wall has been removed)
There are no significant cracks appearing but the two upvc windows on the first floor of the rear wall now don't close properly. You can close them but they need hard yanking rather than the previous smooth operation.
Is it reasonable for there to be some movement like this when structural walls are removed, foundations are underpinned etc?
Thanks for your advice
