Hi, following on from some good prep help I've got here already, I thought I would tap the knowledge bank for some advice on the painting itself - paintbrushes, rollers and paints!
1. When cutting in, what sized paint brush do you normally use?
2. In terms of rollers, I've normally used a smooth or medium ' whatever' roller from B&Q without really thinking about it, but the more I've done, the more I appreciate that when I've randomly picked up a more expensive roller, the finish is nicer.
- So what do you recommend in terms of a standard roller for wall emulsion?
- Would you recommend different rollers for different paints (flat matt or vinyl matt)?
- Also when you get to to around the tops of doors, do you switch to a smaller roller or just cut in a bit more to help with the coverage?
3. And possibly where I am most confused is the missus is wanting Farrow & Ball on the walls. Theres some positive sentiment towards them around this forum, but generally that (price aside)
- they can be thin and need an extra coat/you get poor coverage
- they knock/scuff easy
- are hard to patch up
- but they do give a good flat finish and you get a good range of colours with good 'depth' due to their more natural pigments.
I don't really want to turn into a love or hate farrow & ball posting, but I'm looking for reasonable alternatives.
I've seen suggestions that the Dulux Heritage flat matt finish is very good and with their colour matching is an alternate option to get that flat finish. Does the Dulux stuff suffer less from the knocking/scuffing/hard to patch up? Do you get better coverage from them.
Also there seems to be a Dulux Trade Flat Matt - does anyone here know how does that compare to the Heritage range? And also would it need thinning at all?
Further, does anyone have any other recommendations for what I'm after?
