I was considering mixing my own concrete on a future project. Some questions:
1. What's the correct mix ratio for "C20" concrete? (using ballast) Depending where I look this varies from 5:1 up to 6:1. Any ideas?
2. On my paricular job it will be much more practical to buy 25kg bags of ballast than a big giant bag. I was thinking of using the Wickes stuff (pretty cheap and easy for me to get hold of). However, I'm confused as to whether the Wickes stuff is acceptable or if I need to use something different, specifically I keep seeing "20mm ballast" being called for, not sure if the Wickes stuff is 20mm.
3. To mix the stuff up I would like to bung one bag of ballast (25kg) into the mixer then the appropriate amount of cement (5kg if using 5:1 ratio). However, I guess this would mean I need to find a container to guage 5kg of cement. Perhaps a better option would be to guage both the ballast and the cement by volume (5 buckets of ballast, 1 bucket of cement).
Any tips/suggestions much appreciated
