some questions about how combis work...
5 Aug 2008
Berkshire
hi
our combi has a primary and secondary heat exchanger. why does it need 2? do they do different things?
if the heat exchangers have scale and magnite on them from the radiator system, doesnt potential drinking water that passes over them get contaminated? i assumed that with a combi you could in theory drink the hot water it creates as its not stored in a HWC and comes straight from the mains? there could at least be some left in the pipes when i go to pour a glass of cold water couldnt there?
how can a combi heat the rads and provide hot water at the same time? how does it separate the 2 flows?
hi
The primary HX heats the sealed system water as used in the CH loop and is heated directly by the burning of natural gas in the boiler. The secondary HX transfers heat from the system water to the mains DHW output. DHW is not directly heated by flame.
No, a water-water heat exchanger does not mix the water in the two systems, merely transfer heat between the two by natural conduction of heat from an area of high temperature to an area of low temperature.
Correct.
How is that any worse than the water sitting in your cold water pipes all the time whenever a tap is not running?
It can't. You either get CH or HW, and this is controlled by a diverter valve.
very interesting thanks
sooo...
how is the DHW heated when the CH isnt on ie during summer?
