is there an ideal temperature that rads should be? mine are aprx 57 degs at the top and 52 degs at the bottom.
how much difference bertween top and bottom is acceptable? 57 feels v hot to touch but 52 feels much cooler.
if i want my rads hotter should i just turn the temp up at the boiler? the rads are on max at the valves. the boiler is currently on around 61 deg.
what do the numbers on rad thermostats correspond to? why dont the thermostats just tell you what temp the rad is at rather than some arbitory number that doesnt seem to be consistent between rads and between thermostat makes.
do the numbers on the thermostat correspond with room temp or rad temp?
cheers
cheers
