- Joined
- 17 Jul 2024
- Messages
- 3
- Reaction score
- 0
- Country
Hello Alarm pros.
I am looking to install a Texecom Alarm in a new house. I have no experience with installing alarm systems but am doing some research.
Besides having pir detectors and smoke/fire detectors I was also looking into maybe wiring some water sensors like these ones: https://www.grisk.com/wp-content/uploads/mdocs/C_ES 5 Water Sensor Relay 2500 2600.pdf
I was planning to go with a Texecom Premier Elite panel and wiring some water sensors into a wired zone expander. Now I don't want the sirene to go off when a faucet leaks. I would prefer getting a notification on my phone (i am planning to integrate the Texecom Premier Elite into a home assistant that will send notifications to my phone when the water sensor zones are being triggered) and maybe something that beeps INSIDE the house.
So I grabbed the manual and started reading.
I see there are all kinds of different zone types you can configure for your zone. I was looking through them. The following one popped up as a possible candidate:
Q1: I couldn't really find the defenition of a "Silent Alarm". I assume nothing beeps and nothing is visible on the keypads and it just notifies the external configured contact. Is that correct?
This doesn't seem like the settings I want, so i continued reading. I noticed there is something called 'custom' zone type. I think this could be the one I need.
The configuration settings for the custom zone are the following:
So I was thinking to configure it like this:
INTERNAL: ON
BELL/STROBE: OFF
MONITOR 24h: ON
ENABLE CON: OFF
WARNING REQ: OFF
Now I got some more questions.
I was planning to put a wired sirene outside and wire it to the pannel. I think it is pretty clear that this would counts as the BELL/STROBE.
Q2: Now for the alarm system I also want to have an internal sounder(s) for the fire alarm when people are sleeping. It is unclear to me how this can be achieved.
I see the keypads have a built in buzzer. But I think this is only to let the user know a key was pressed, the alarm is being armed etc, is that correct? They don't suffice to wake up people when the alarm sounds, right? The buzzers in the alarm pannel are not the so called 'internal sounders', are they?
Q3: What does count as the 'internal sounders'?
Q4: Is it possible for something such as water leak detection to only sound the buzzer on the alarm pannels and don't have the sirenes go off?
Q5: I see you can also wire 'loudspeakers' to the pannel, are this the so called 'internal sounders'? If so, I assume these can go quite loud and wake you up in case of a fire alarm?
Q6: So to summarise, for me it is a bit unclear what the difference is between: the buzzer inside the keypad, 'loudspeakers' which you can connect to the panel, and the so called 'internal speakers' that are being referred to by the manual.
Q7: I want to be able to sound the internal sirenes and the external sirene when there is fire and an intrudor. In case of a water leak detection I want to have maybe the buzzers inside the keypads play a sound or a very low volume on the internal sirene if possible.
I know these are many questions and I do appreciate everybody reading through them and sharing their experience. I have already watched many videos and read a fair share of posts regarding Texecom alarms, but this one regarding the sounders/sirenes etc got me really confused.
Cheers,
An Alarm newb
12 - Auxiliary
This zone type will cause a Silent alarm if it is activated when the system/area is armed or disarmed. The panel will also report an Auxiliary alarm to the Alarm Receiving Centre when using ‘Contact ID’ reporting.
I - INTERNAL
Activation of this zone (when armed) will cause the internal sounders
to activate.
B - BELL/STROBE
Activation of this zone (when armed) will cause the external
sounder/strobe to activate.
M - MONITOR 24Hr
The zone is armed at all times.
C - ENABLE COMS
Activation of this zone (when armed) will cause the area ‘Alarm’
output to activate.
Note: Any Custom zone with this attribute will activate both the
internal and external sounders even if they are not enabled
above.
W - WARNING REQ.
If the zone remains Active for the duration of the ‘Warning Delay’
timer (see page 70), a warning tone will occur every 30 seconds for 3
minutes (or until a code is entered or R is pressed).
Note: If MONITOR 24Hr is enabled, an internal alarm will occur after
the Warning Delay
INTERNAL: ON
BELL/STROBE: OFF
MONITOR 24h: ON
ENABLE CON: OFF
WARNING REQ: OFF
Cheers,
An Alarm newb
