- Joined
- 26 Feb 2018
- Messages
- 9
- Reaction score
- 0
- Country
Hello guys, for quite some time I have had annoying issue with my central heating system but I'll write some background to explain that a little bit more.
So we have bought our house last year in september and done a full refurb in it meaning we removed all the radiators as well to get them moved from very inconveninent places in the room undernath the window (which should be obvious when they were installed the first place). We have also added 1 extra radiator to the system and changed another one for a vertical one.
We have 4 radiators upstairs: 2x single panel 120cm, 1x single panel 90cm and 1x single panel 60cm
Theres also 5 radiators downstairs: 2x Double panel vertical 180cm high double panel, 2x double panel 70cm and 1x double panel 40cm.
The 2 vertical ones that are now separate used to be a single 180cm single panel radiator but since now kitchen and living room is an open plan and vetical units are much more space efficient we had to add these instead.
At first for first week or so it was all fine while we did the finishing jobs and were putting the laminate flooring all around the house. The vertical radiators took slightly longer to heat up but I assume thats normal since they are quite high and all the other radiators were heating up quick and were boiling hot. the central heating used to work for 10 hours a day at then since we were in and out the house and it was january so quite cold. Also everything like paint had to dry up fairly quick. Then the problems have started at which point no changes were made to central heating since it was working just fine. Once heating is on all the radiators downstairs get hot but upstairs when all are on then the two 120cm ones only get half hot wich is jut the top part and its not even hot but warm. Although if 90cm one gets turned off aslong with 60cm then the bigger ones get hot immediately.
I have had all the radiators checked and even replaced the two 120cm for new ones since we thought theyre blocked but theyre not in fact. Pressure seems to be strong at all pipes upstairs when we took every single radiator off to check if there's a flow which is flawless. System has been drained and cleaned seveal times and its all clean as far as we know but problem still occurs.
I have to get it sorted as soon as possible since the temperatures as off last night got quite low and we need to start heating the house up. befre that we had the two radiators turned off as the reception room is fairly warm usually during the day and not used often as well as the toilet which has small radiator but we are at the point where all radiators need to work at full heat.
I suspect the pump is not powerful enough or it is giving up but i need an option and suggestions of those who are more skilled and with far better nowledge than myself.
The combi boiler is situated downstairs undernath the stair case and it's a Main Combi 30 Eco wih Grundfos UP 15-60 A0 pump. I thought the pump has 3 peed settings and it might be set to the lowest one but I took the front cover and it turns out its just a basic pump without the option to change its speed so has only P1 setting at which it runs at 90W.
Any suggestions are much appreciated and if there's anything I missed please let me know as I am now desperate to sort things out, nobody wants to wake up to cold house.
Thanks a lot in advance and thanks for any help given.
