First-time post, I'm not particularly knowledgeable in plumbing matters...
Just had all the upstairs radiators replaced in our house (4 doubles and 1 1800x500mm towel rail) and the system balanced and boiler serviced. Aside from reasons of aesthetics we also had the work done because one of the four bedroom rads would only get slightly warm (bed 2), and one not hot at all (bed 1). A couple of plumbers had suggested the radiators may have got sludge in them so flushing or changing them should help.
These two now do actually get warm but much more slowly than any others in the house. The plumber who did the work thinks the upstairs in only plumbed in 15mm pipe and this could be the reason, though he did suggest trying a new pump (currently a BG/Grunfoss multihead G). We have a four year old Worcester boiler, hot water tank run from the boiler (both on the ground floor next to each other) and the usual header tanks in the loft. There is a magnaclean on the system but it hardly gets dirty. There are 5 radiators downstairs which heat up quickly, and beds 3 and 4 rads heat up fairly quickly as well).
I've been looking at the pipes to and from the boiler to try and work out how the existing pipes are laid out. The flow (in 22mm) after the pump works its way down into the ground floor, but there is no branch off up the wall to upstairs. Instead there are two 15mm pipe runs up the wall behind the hot water cylinder - they come up out of the floor and go up through the ceiling to the first floor, I cannot see any connections to them in the cupboard. One gets hot after the downstairs radiators have started heating, and the other only warms up after quite a while (maybe 30mins). I assume that these are therefore the flow and return to the upstairs radiators, but it therefore seems that the water has to flow all around the downstairs radiators before it can make its way upstairs? If so I guess that's why it takes so long to heat upstairs and perhaps why the two furthest bedroom rads from the boiler barely get hot?
Can anyone comment:
- is that a normal design, or should there be a split after the pump to the upstairs rads
- could the 15mm pipes upstairs be sufficient if the water didn't have to circulate downstairs first?
- is there a way to improve it without pulling up all the hard flooring upstairs?!
- do I need a better pump?
Any input will be greatly appreciated...
Can anyone comment:
