Model kdl32v 4000 When attempting to turn on from off rather than standby you have to push the button 3 or 4 times for the green light to come on, I have tried all the disconnect from mains and reset along with disconnecting sky box and disc player ideas but it makes no difference so could it be the switch that needs cleaning or could it be a condenser that is on the way out? I say this because if you turn off at switch and straight back on it will 9 times out of ten power up.
I have tried the set remote and that makes no difference although we only use the sky one and it is never left on standby.
