HI,
I have a sony DCR-PC120E camcorder. The IEEE 1394/ilink/firwire socket appears to be faulty. I was told that to replace it the cost would be £110. And that most likely it is the PCB which would cost £200+ to fix.
I am not convinced it is the PCB becuase when I plug the cable the camera shows DV IN however the computer does not detect the camera. HAving said that the socket on the camcorder appears to be damaged.
the actual IEEE PCB socket costs about £2 or less, however I have not been able to get to that PCB. I took the camcorder to pieces but the only part that I could not get too easily was the PCB.
Does anyone has any ideas on how to get to that PCB? There are a number of screws but I do not want to start removing unnecssary ones. Ideas thgouhts are welcome, also any expert opinions on whether the PCB is damaged? I am assuming it is not becuase it is showing DV-In that means the PCB is detecting the Cable.
Thanks.
Regards
Charbel.
Thanks.
Regards
Charbel.
