Hi
I have purchased a shower bath (P shaped (and the complete suite)) and it is to be fitted across the width of the bathroom. I tried fitting the legs on the rear of the bath (opposite end to the tap), tightened them up and let go, and they buckled straight away, slightly bending the brace bars underneath. I am now greatly concerned about the bath. It appears that the holes the bolts/legs go through, once bolted seem to be too big for them and hence no strength to support the weight when empty.
There are also two clips provided that go under the lip along the wall and come above the top of the bath and will need to be cut into the wall but with the above issue I don't think that will be enough. I would build a frame except for the fact it is a P shape.
So basically ........HEEEELLLLLLLLPPPPPPPP!!!
All advice greatly appreciated
Cheers
Steve
Cheers
Steve
