Hello from a newbie here!
We've just bought a flat (middle floor, but three out of four walls are external) and as it hasn't been updated in 25 years need to deal with quite a few issues there.
The major one, as I see it, is sound and thermal insulation, as heating bills in the first month of owning the flat are astronomical. We can also hear everything from one room to another.
So so far, from my limited research, I have come up with the following plan:
1. Install double plasterboards on the outside walls with Green Glue between them.
2. Install a single layer of plasterboards on ceilings (Artex at present) and internal walls, using Green Glue and screws to attach plasterboard to the walls (painted vynil wallpaper at present).
Would it help to keep noise and cold out? What would you think? Or shall I double drywall everything?
As it is a flat, I am rather limited in what I can do to walls; also, because of space restrictions I really need to have as thin new addition to walls as possible.
A related question is about electrics: at which point do I need to invite an electrician: before or after I have plasterboard fixed?
Thank you in advance!
