My house is terrible for sound proofing, both floors and walls. From the master bedroom you can hear people talking in the lounge as if they were in the room, and you can hear the trickle of the shower running in the bathroom - 2 entire rooms away! Not to mention when someone is playing the piano, even moderately (hard to adjust the volume on a real piano ) the neighbours start banging on the walls . The floors are also very 'boomy' as in you can hear people moving about even when they tread lightly.
I get the feeling my house was slung up in the cheapest possible fashion (or maybe this is just the modern way). There are no 'solid' walls, everything is plasterboard over metal rails - even the 'exterior' walls. The upper floors are actually quite thick - they are made of what I can only describe as wooden "I-beams" - two flat joists with a vertical chipboard section between them, about 50CM apart, with about a 30cm air gap between ceiling and floor.
I'm about to do some major work, moving some internal walls around, and replacing all the flooring, so I want to take the opportunity to put as much simple sound-deadening in as possible.
I assume the best way to achieve this is some sort of sound-deadening fireproof foam type material in the cavity?
Can you give me some suggestions for - firstly the walls (I've had a peak and there is about 7cm gap between plasterboard and blockwork). And secondly the floors - it's a big gap to fill.
Cheers!
Cheers!
