I've stated on my full plans submission that I'll put 100mm of sound insulation between the floor joists to separate the ground floor dining room with first floor bedroom.
Is there a particular product I should use to comply with regs - does it need to specifically be acoustic insulation or will cavity bats, loft rockwool etc do the job?
Also, it's a 200mm deep floor, so I presume I'll ask the electrician to route cables through holes made in the centre of the joists allowing the insulation to be beneath the cables, sitting on the plasterboard?
Gary
Gary
