The party wall in our flat backs on to the neighbours lounge. He is not noisy but we can hear his TV. It's a corner flat on a road, but for some reason it's the tv not the road noise that I pick up on. As i'm conscious he can hear our TV.
The wall must have previously had a door as when I stripped it back I found a hollow cut out with just plasterboard either side! I have since filled this with insulation. I also lifted the floor boards and stuffed any voids with insulation. The wall was then battoned and plasterboard put on. I could hear the TV so I then placed 25mm celotex in the void this has helped reduce the sound. I don't have enough room due to a door frame to batton out further from the wall.
I have thought about installing a layer of sound bloc plasterboard fixed with acoustic mastic. But it will still be tight for me to fit the door due to the hinges.
Could I take the plasterboard down and on the batons fit rubber strips or self adhesive foam to insulate the plasterboard panels? Would that be the solution?
Thanks for any help.
