I know if putting in underfloor insulation for heat-loss purposes, then some form of netting must be attached to hold the insulation up to the timber floor and still permit the travel of air between the joists.
However, if putting in 5 cm thick sound insulation slab (not for heat-loss purposes) under timber flooring, where the joists are 20 cm deep, can the slab be simply set down to the bottom of the joist without the need for any netting? Presumably air flow will still be permitted over the top of the slab?
This would be under the floor of the 1st floor.
Thanks.
Thanks.
