Sound proofing airing cupboard
Tjs
29 Apr 2013
Kent
Hi all I have just recently had a combi boiler installed in the up stairs airing cupboard, I am just wondering if there is certain sound proof blocks you could get hold of at a decent price, if anyone could post a link that would be great. The boiler is just a tad noisy when starting up. Thanks.
Yeah thanks andy funny man!! Lol. Thanks foxhole ill try that.
I' thinking that you want to insulate for sound and not heat. You don't want the airing cupboard to cook inside... Peg board (hardboard full of holes) lining the cupbaord, mounted on battens could create a baffle for the sound but allow the air to circulate and the cupboard to keep cool.
Otherwise, most thermal insulation will keep the sound down - fibreglass, Celotex, fibleboard, egg boxes... (I new a sound studio lined with egg trays...).
Seal around and under the door first with draft excluder. If that's not good enough, stick some old carpet underlay inside the door.
you need to check if the sound is mainly airborne or structurally transmitted
you could surround it with quilts and such to see how much difference insulation will give before spending a fortune on the correct stuff
it may be something simple like the pump need rubber mountings or some other physical separation from the structure
if the existing door is a lightwight thin wooden door, or a cheap hollow one, made of air with a thin wrapping of ply or hardboard, swap it for a fire door. The extra weight and density means they are very good for deadening sound. They are available flush or panelled. Adding draught strip or furry pile strip will blot sound getting round the edges.
Might be a idea to get a gas engineer to check everything is working correctly, I'm not Gas Safe so can't advise but I do know the timing of the ignition slightly delayed or pressure switch etc can do this. You could ask on the plumbing section for further advice.
It ok, it's a brand new boiler, a friends one is exactly the same. Mainly when the boiler first starts up. U kinda get used to the noise.
