This topic probably comes up regularly but I'm trying to work out the best 'bang for my buck' for all the possible solutions.
I've done a lot of reading and YouTube and found various suppliers but it is difficult to get a true figure on what sort of sound reduction their products would give. They quote figures around the 40 to 60dB. But I think this is for the total wall.
I'm on a fairly tight budget so started off just thinking about dot and dabbing some acoustic plasterboard but was then told it should be off the wall so use some 25mm batten. But screwing this to the wall will just transmit sound through the screws and the face of the battens, therefor a gap is required, say 5mm.
But how do I fit this frame without attaching it to the wall? Will something like Everbuilds AC50 acoustic mastic be good enough to stick the battens to the wall whilst giving some degree of gap and then being able to hold the heavy acoustic plasterboard. I could space the battens off say 2mm using some spacers in a couple of places which can be removed once the mastic is set.
Any thoughts on this and any other budget conscious solutions.
BTW, I'm trying to suppress normal sound conversation and TV and radios plus a dog barking now and again.
Richard
Richard
