My property is 1920's Town/terrace era.
The walls are solid brick and the joists run through into adjoining properties.
This can be seen in my cellar and also heard! Sound from next door both ways is clearer in the cellar along the joists.
Im wondering if there is a way to plug or cut the joists to prevent the sound/vibration travelling along them without affecting the integrity of the joist.
Obviously any cut would be where the joist sits on the wall if accessible.
But could something be attached or drilled into the joists and plugged to deaden the noise travel??
I also am considering the alternative option of sound proofing and rubber type layers between these joists and wooden flooring on the the room that sits on these joists but would prefer to tackle the problem at the root.
Its a bit of a technical querey but any thoughts much appreciated!
regards
Russ
regards
Russ
