Sourcing a Cooker Connection Plate for 3x10mm Cables
24 Dec 2005
Newcastle upon Tyne
Has anyone come across a Cooker connection plate that will accept 3x10mm cables into the terminal? If so, would it be from a local wholesaler or can it be bought online somewhere?
Thanks in advance.
Chris
Not answering your question but asking a different one.
How come you have to join 3x 10mm cables? The only way I can see you doing it is with a big old 60 amp junction box (you can terminate 25 mm in the biggest ones, so should be able to get 3x 10 mm in).
Good luck with the search!
//www.diynot.com/forums/viewtopic.php?t=64491
Relates to connecting a single oven and hob upto my cooker circuit... i don't want to be putting in a new way on my CU (notifiable and all of my recent re-wire has been signed off).
The way I see it... the easiest way of fixing to problem is to spur off the cooker circuit to a FCU to supply the oven hence 1x10mm for the power, 1x6mm for the hob, and 1x10mm for the spur.
thanks for helping!
