Sourcing a Small Shower Door
21 Nov 2007
Buckinghamshire
I have a small shower cubicle under a sloping roof. The existing shower door is a Showerlux bifold 660mm wide x 1750mm high.
I can't see anything currently available of this size (or very close).
Any pointers, please?
Thanks in advance.
Think the narrowest off-the-shelf size I've seen was 650 X 1850.
Some manufacturers offer custom made sizes and shapes.
Maybe a caravan shower door would fit.
TicklyT,
Thank you for replying. A brilliant lateral thought re caravans, but I couldn't Google anything suitable.
The most suitable ones I've seen so far are by Simpsons - width 600-660 and height 1850. The old tray is 120 high and the new ones are all c60, so the 1850 height ones should just work - but I would have liked to use a mounting frame under the tray to increase the (shallow) run-off.
Anyone know of 1750 high doors? I've got to order tomorrow as my builder starts Wednesday!
Thanks,
Rob
The shallow run-off is from the waste. The current tray holds a fair bit of water - the current ones have much less margin for safety.
Rob
then fit an high flow trap or the pipework hasn't got enough fall or under sized.
should never need to tilt a tray otherwise it can cause untold problems with tiling or the shower door.
seco s,
Thanks for taking the trouble . . . .
No intention to tilt tray or door. But a couple of times in past my kids have unwittingly partially blocked the drainage with soap/paper/etc. So the more safety margin in outflow and tray depth the better!
Now, let me find out what a high flow trap is!!
Thanks,
Rob
