spa bath
17 May 2005
Bedfordshire
i am just about to replace our bath with a spa bath
can i use the cable that used to supply the emersion heater
as it is no longer used ( combi boiler) i can put it on its own MCB
on a split load consumer unit
Do i need to fit a separate switch outside the bathroom or can it go
straight to the MCB
providing the cable is adequate for the rating of the spar, then you could use it. out a SFCU outside the bathroom. dont take it direct form CU. and itll go on the RCD side
