Hello,
Can anyone help. I am currently in the process of relaying wooden floorboards in my lounge and I want to insulated under them. I plan to use Knauf space blanket (because it is cheaper than insulation board and the joists are uneven in shape and spacing) but there are a number of heating pipes under the floor which will help keep the floor warm but will be between the insulation and the floorboards. I know the usual advice of allowing air circulation to the joists ect but want to check that i am ok to use space blanket with hot pipes running over it (between the insulation and the floorboards) as i have not been able to find this information anywhere else on the net.
Thanks for any help.
