I am having problems with kettling from my boiler, a Glowworm Spacesaver 38.
I have purchased Fernox Restorer which i'll put in for a couple of days to see if it has any results.
The problem I have is that there is no drain point on the gravity hot water pipework and I am unable to find a drain on the boiler. I've tried to find schematics for the boiler, but believe that the boiler is that old that it was designed by a caveman on the wall of his cave, and thus, no schematics are available!!
I am confident I can drain off the rads ok, but am concerned that if I put the product into the header tank for the hot water I can't then get it out.
The questions are therefore:
1) Does anyone have any knowledge of a drain point on the spacesaver 38?
2) or any other way I could drain the gravity hot water system?
3) is the heat exchanger in this boiler, separate for hot water and heating?
