When entering the span length in a beam calc program like Superbeam should it be the clear span or the span between bearing centres?
I have two load bearing walls 6m apart which I wish to span for a loft conversion. The beam will be placed on 100 mm wide bearing plates or pad stones so the distance between bearing centres will be 6.1m. Should I use 6m or 6.1m for my bean calculations?
