No it is NOT scaremongering.This is just unhelpful scare mongering by so called "professionals" trying to put off DIYers.
it is not a safety feature.
The expansion vessel is purely for the practical purpose of stopping the loss of water through the pressure relief valve when water is heated and expands, it is not a safety feature.
Surely the reason for using WRAS hose is concern over the growth of micro-organisms tainting water or even supporting the growth of Legionella. This is why it must be used for drinking water and other uses which might expose the user to atomised Legionella spray such as showers. I can see no reason why it is necessary for a central heating application where the temperature would kill Legionella and the risk of spray is minimal.
There is absolutely no connection between WRAS hose and the risk of explosion, that is controlled by the pressure release valve and in any case for a boiler to explode it would have to exceed the boiling point of water. If a component was weak it would just leak not explode. WRAS is about water quality not strength. This is just unhelpful scare mongering by so called "professionals" trying to put off DIYers.
