I've had a google and can't find anything that answers my question specifically.
I have just moved into a new flat and want to mount my TV. It is 42" and weighs about 9.5kg.
I have a mount (this one here) that can hold up to 50kg in weight (which allows full swivel of the TV).
As for the wall... It's an external wall, and I think it is plasterboard. I would be drilling through the plaster and into what seems to be a vertical concrete beam of some sort (not sure of the correct terminology).
Anyway, I can only drill into the wall about 40mm before I hit the concrete. The screws that came with the mount are 4x 8.8mm diameter with 63mm of depth. This will mean that only 23mm of the screw goes into the concrete.
So my question is this... Will I be safe to install a 9.5kg TV into the wall using only 40mm screws, rather than 63mm screws?
Thanks in advance,
Matt
Thanks in advance,
Matt
