Hi All
I am knocking through a bathroom/toilet. On one side of the wall that is going is a towel radiator and on the other side is a tiny radiator. A new towel radiator will be purchased but it appears that nearly all of these have the fittings coming out of the wall. The small radiator in the toilet will be redundant.
What i need to work out is, is it possible to put up a wall mounted towel radiator using speedfit fittings (the plastic things)? The wall that the radiator will be on will be a masonry wall so channels will need to be cut etc but not too sure if its possible to do this kind of work using these plastic type, anyone done this before. Is trunking required? Plastered over etc
I plan to just extend the existing ins/outs to the new site for the towel radiator.
Also i want to decommision the redundant radiator. Is this as easy as just capping off the ends?
L
L
