- Joined
- 2 Nov 2009
- Messages
- 631
- Reaction score
- 73
- Country
Hi guys,
I am currently refurbishing the bathroom due to a cracked shower tray
my problem is with the pipework to the shower. The original shower mixer was fed by 22mm pipe, pressurised by a twin 3bar pump. The new mixer requires 15mm fittings so I intend to cut back the existing pipework and add isolators (currently none are fitted) my problem is that it will be really difficult to do this in copper due to a combination of tight access and risk of incinerating the bath, so I am looking at using plastic speedfit (JG of course) my worry is 15mm plastic has a much smaller internal diameter to copper tube will it be ok?
plan is/was
- cut through 22mm pipe and add 22mm to 15mm reducer, then add isolator then run pipe up stud wall to mixer valve
is this ok?
plan is/was
is this ok?
