speedfit to compression
Thanks so there for connecting to flexible tap connectors with a 1/2 female thread then?
You don't need a speedfit fitting to go to compression, just fit a sleeve in end of tube then compression on to that.
If you told us what you were trying to do, it may help us give you the correct info.
Thanks and speedfit fittings can except copper? I usually use polyplumb or just copper.
