I've never used plastic pipes for plumbing before, but i'm just about to redo the whole bathroom so i bought some 15mm speedfit pipes and connectors.
After trying them to test the connections i noticed after inserting the pipe inserts into the plastic pipe the actual pipe diameter is now nearly half that of a copper pipe.
Surely this will affect the flow rate to the shower, bath and taps?
I'm tempted to use normal 15mm copper to ensure a decent flow rate.
What do you think? Will i see a difference?
Thanks a lot.
Thanks a lot.
