SPELLBIND SHOWER
13 Jun 2008
Glasgow
Hi I am hoping someone can help I have a Triton Spellbind shower which up until a couple of weeks ago worked perfectly, but it switches off after not even a minute the digital display turns from blue to red with LP flashing which I presume means low pressure I not sure why this is happening my water pressure seems ok. Can anyone suggest anything ?
Cheers
check your filter on the mains inlet to shower. if ok check the pressure valve micro switch is activated when shower switched on (bottom righthand corner)
you may also want to clean out the scale trap (bottom lefthand side)
if not you may need to check your mains inlet pressure to house or any restriction in pipework
Just want to say thanks for your advice :D Hubby gonna have a look at it right now Ill let you know how we get on.
Heather
Hi again can i pick your brain once more not sure how to check if pressure valve micro switch is activated can you help once more
with the cover off and shower hose in bath etc remove cover and watch the micro switch , turn the shower on and see if the pin activates the microswitch .
the water pressure passing through pushs the pin on to the microswitch
