spindle spacing
14 Mar 2007
Staffordshire
Can someone help this thick person with a formula for fitting spindles. I have a space of 910mm and eight (32mm) spindles on 45 degree stairs and spaced them at 113mm, but the distance from the inside of the newel post to the first post is greater than the spaces between rest of spindles. I place the spindles across the 113 lines.
Tony :confused: :confused:
if you have a gap, space, whatever and you wish to divide it into set increments then think of the amount of spaces between spindles and not the amount of spindles themselves.
if you have 8 spindles then you are creating 9 gaps.
whatever the overall gap divide by 9 and this will give your spindle centre mark. i.e 910 divided by 9.
If you have a total space of 910mm,
then 8 spindles x 32mm = 256mm
910mm - 256mm = 654 space left
Therefore 654mm divided by 9 = 72.6mm space between each 32mm splindle
yep masona is spot on except [not being pedantic :D ;) ]you need to cut your spindle at the correct angle [42% for example] that will increase the coverage by around approximatly 25 percent so 38 will =around 47
now it may not seem a lot but 9x 8 is 71mm aproching 3"
this of course assumes your measuring under the handrail or on top off the string :LOL:
Just finished converting my stairs from ranch style to turned posts and spindles.
1.Use the formula to work out minimum number of spindles required. Cut them and put them all in at the bottom of the run tight up against the post and each other.
2. Measure the remaining space horizontally, clamp spirit level to the post if that helps.
3. Divide by number of spaces.
4. Remove a spindle, glue and pin at the top, correct distance horizontal from post.
5. Cut angle on infill, mark and make repeat cuts (shows how to easily do all this at website)
6. Fill up about halfway then redo process to check its going ok, adjust spacer size if needed.
can i just suggest,iirc the spacings for spindles can not be more the 95 mm apart on the horizontal.
I think the reg is 100mm but i stand to be corrected.
yes pedanticly "less than 100" so a 100mm sphere cant pas through so 95 allows for bumps twists and moldings on the spindles and for you to stretch a couple off mm to fill the space ;)
Top man i didnt know that tbh.. It all makes sense. Gotta love the buildong game. Been to some jobs where they have been around 120 also tho
