Spindle touching newel. Advice please!
12 Jun 2018
See pic, of the stairs that have just been installed for a loft conversion.
Is there any circumstances when this is actually ok? Or has someone made a mistake.
Essentially the first spindle touches the newel post, and then there are 2 spindles per step, done decently, evenly spaced, until the top of the stairs.
Greatful for any thoughts asap.
Thanks, Ash.
off no importance regs wise as long as you have no gaps greater than around 95mm[100mm sphere size]
that aside not nice in my eyes:eek:
looks to me that they concentrated on getting two spindles per step.
and didn't think about the bottom.
Whe I did mine I calculated the overall thickness of the spindles at the base, checked the spacing was in regs and fitted the spindles so that the spacing was even.
rollin rollin rollin....keep them wagons rollin
Yehaw :ROFLMAO:
Basically, the chippie hasn't worked out the spacings correctly.
He's having a giraffe :mrgreen:
A You measure the length of the base rail between newels on the angle
B you measure the exact length the angle cut takes up of a spindle up the base rail
C multiply one by the other.
D deduct the answer from A
E divide C by the number of spaces (no of spindles +1)
answer should give you spacing which must less than 100mm.
The spindle spacers can be knocked off and the spindles re-fitted -unless theyve been glued really well.
