M
marsaday
I am changing over a heating only boiler to a combi and relocating it at the same time.
The pipe work needs to be changed a bit, so the spirovent filter no longer sits between horizontal pipes, but vertical ones. This is the older model which hangs downwards. Is it ok to use it, basically on its side ?
If not i suppose we could do the return pipework to fit this filters requirements as before, but vertical pipe will be a lot neater.
