Splicing into wiring circuit for out site light
5 Nov 2019
I am looking to splice into an existing lighting circuit for a new outside light.
I have run the cable from the new switch up to where I am looking to splice into the existing circuit. However the ceiling rose being fed by 3 cables - is there an easy way to check which of the 3 I can splice into without getting caught up in the switched live currently controlling thar ceiling rose?
Reading all the tutorials online they seem to negate this issue?
Can you not just get a cable directly into this ceiling rose?
Isn't that what OP is asking for advice on?
No, I thought he was asking how to identify a switch cable without actually entering the ceiling rose, as he mentions splicing, which to me means jointing into a cable.
I hope so, but maybe @sparkwright saw the word "splice" which has different implications.
Generally the only people I've heard use the word splice while doing electrical work are foreigners, in the American language for example it generally just equates to our use of connect or join. As such I assumed this to be the case here
Hi all
Sorry for the confusion but basically the ceiling rose is already full with the 3 cables and a tiny hole through the ceiling so was hoping as I already had the floor boards up running the new cable that it would be easier to joint in the ceiling void rather than trying to squeeze it into the rose.
Hi all
Joints must be either maintenance free, or accessible for inspection and test. Google maintenance free junction box if that's what you decide to do.
Yes you could put a maintenance free JB under the floor. Just identify the correct cable by looking in the Rose.
but I’m surprised you can’t get another cable in there. I’ve seen quite a lot squeezed in, and you can usually cut an extra hole.
A lot depends on how the existing work has been done but 4 T&E's in a standard rose is usually very simple, but it does mean having 2 wires in some of the holes which some are wary of.
