I need to make a few repairs to some vertical bars on a timber frame using the following method shown in this image
How best and what tool would you use to cut that mitre (indicated by the arrow) bearing in mind that id have to make that cut in situ for the window im working on.
(cant remove the entire frame since it forms part of a conservatory structure)
Id be splicing in the new timber with the use of an epoxy filler like timbabuild so i was thinking to just make the cut using a fine hand saw and any gaps in the final fitment can be filled with the epoxy.
any other suggestions?
