I have a Biasi Garda Plus HE combi M110.32SM/E.
Every time you use a hot water tap (any one) you boiler gives off a loud foghorn type noise, which lasts for approx 10-30 secs!!. It does this with the CH as well, but intermittenly. It appears to happen everytime the boiler ignites if thats any help. The original installer has no idea what the problem is and he's washed his hands off it!!! The gas inlet level is OK and the CO2 level is within the manufacturers spec. The pressure is also correctly set at 1.3 bar as per man spec. This has been going on since it was installed a few months back!!! Any ideas anyone, would appreciate any help on this one.
Regards
DS
_________________________________
lynda, moderator
please note forum rule 20 (I was able to split your post)
Regards
DS
lynda, moderator
