Hi, mine has done the same. Sentinel CA67.
Had a power cut and now the system wont set using my code. Both the main box and and remote panel have power and appear to be working ok. (beeping fine).
When I enter my code or 1234 nothing happens (it would usually set). The user reset does not work either?
I switched the power off and left it for 2 minutes. When I powered the system back up the panel beeped and the alarm started to sound. I keyed in 1234 and it stopped. But if I key in 1234 to set it I get nothing???
Could a dead battery inside the panel cause this? When I cut the power from the fuse box all the power lights go out on the main and remote panels.
Or any other ideas?
___________________________
Lynda, moderator
please do not hi-jack posts
Thanks,
Or any other ideas?
Lynda, moderator
Thanks,
