SPLIT: strange central locking problem
8 Aug 2007
Fife
My 02 Focus has recently developed a strange central locking problem. The key fob button locks & opens all doors expect the drivers !! . I can only lock / unlock the drivers door manually using the key.
Any ideas for cause / solution ?
Cheers
____________________________
Lynda, moderator
Your post has been split, please read the forum rules
sounds as if the door actuator could be knackered,can you hear any motors whirring inside the door when you operate the locking?
I had a similar problem with my central locking on my nissan serena, I sprayed the moving parts and actuator switch with wd40 and this has worked.
Hopefully it is a similar problem with your door.
Steve [/u]
Thanks Ch427 & Steve.
I've just been out to see if I can hear the actuators moving, but strangely the central locking is now fully operational again !!!
I cant decide if this is a good thing or not (think it's a good thing) since sometimes an intermittent problem can be tricky to correct.
I'll just need to keep an eye on it for a bit.
Cheers
Col
its a ford! and ford = crap electrics
i should know i have had a wiring loom, every door lock, 3 key fobs central locking actuator and numerous other parts changed on my 53 plate transit connect heap of junk!
