Just a thought. I would like to see plumbing and central heating seperated. IE a topic heading for Plumbing and another for central heating. What do others think?
has been mentioned before.
i would say a good idea then we can keep away from those who want to put the world to rights about who should/shouldn't be looking at your system
Id love the mods to try and seperate it. A lot of customers think I can drain the heating system by turning off the water and open up a kitchen tap. Shamefull I know, but some are that un-educated!
Where do you draw the line... a compression fitting leaks? Can of worms as some people have no idea what the water that is leaking does. Maybe advise and then direct to a seperate forum?
Anything that needs certification (ie Un-vented) maybe should be seperated.
