splitting an existing supply
20 Mar 2010
Surrey
I want to convert a single supply for a house into 2 separaate supplies for 2 flats. The existing supply is via a supplier fuse of unknown rating and 16 mm tails which lead to a Henley box. 16mm tails then lead to a redundant off peak meter and another set to a CU (split load 100A isolator and 80A 30mA RCD} This CU supp;ies:
2x 32A power rings, 2x 6A light rings, 1x 16A immersion. 1x52A cooker/oven and a 10kW shower.
Can I
1. ask the supplier to upgrade their existing fuse ,if necessary
and also change the 16mm meter tails to 25mm.
2..insert a 100A isolator switch after the meter tails and connect this to a Henley block leading to two CUs using 25mm tails.
One CU to supply 1x32A ring,1x6A ring, 1x32A cooker and the
second CU to supply 1x32A ring, 1X6A ring, !x16A immersion, 1x32A cooker/oven and 1x10kW shower.
OR
3. in view of the additional load i.e. another cooker/oven and possible greater demand by two flats for light and power, will i need a to have an additional supply installed.
I would appreciate your advice on one or all the above. Thanks in anticipation. helector
Have you got two meters ? Splitting the supply into two flats after one meter will give you big headache when you tennants start to argue over power useage. :)
you need a seperate supply for the second flat..
with a cooker and shower in each there's a bloody good chance you'll overload the main fuse
Part P makes this notifiable work also.. but presumably you've already applied to the LABC for the conversion.?
Thanks Gees. No only one meter at present but thought would install one sub meter. Probably a card meter cos intend to live in one flat myself.
Can do without second shower but definitely need another elec cooker cos no gas in area. Will contact Building Control and also investigate cost of new supply.
Thanks, any ideas about keeping down cost?
Just going to rob a bank or become a banker/MP.
