Hello all,
I have a vented hot water/GCH system. The hot water has been spluttering for some years now after I had the GCH pump replaced.
I thought it would get better once the air had worked through, but this hasnt happened.
Where is all this air coming from? How can I (or a plumber) stop it coming in?
Also, I have noticed a damp patch on an interior wall close to where radiator pipes run. If there was a leak in these pipes causing the dampness, could air be sucked into the system at the same place?
Thanks!
Thanks!
