Spot bond
17 Apr 2008
Anglesey
I have seen hot bitumen spot bonded, and some dont use the felt with holes in
should you always use the felt with holes in, so the deck can move
or is spot bonded done so the deck can move
The felt with holes in (3g) is a vapour control layer which is usually laid loose, or part tacked. The next layer either torch on or hot bitumen applied 2mm underlayer then forms the spot bond onto the deck- to allow for thermal movement.
