Hi One of my low voltage spot lights blew.When I went to replace it found that the block connector had melted and also that the transformer was U/S.Got a replacement 12v 50va transformer replacement and rewired up
bulb (12v 50w).The light works fine but after a while the light goes off I
think the transformer thermo switch is tripping cooling and then light comes back on.The other 2 spots lights are fine.Would reducing the bulb down to 12v 20w cure this as transformer said 50w bulb was max or is their an electrical problem???
