spot lights
30 Nov 2009
Hi, hope someone can shed some light on a project. (':D')
I am thinking of replacing the existing pendant lights in the kitchen and extension to spot lights in both areas controlled by switches from either room and am a little confused to the wiring for the switches.
I will run the 1.5 mm twin + earth for the lights and 1.5 mm 3 core + earth for the two switches, also will run 1.5mm twin + earth from the first of the lamps of each room to their respective switches. The supply will be from the cu to a junction box and the two circuits of 1.5mm T + E will run from there to the two rooms.
