Pump started making a horrible "whirring" noise. Been increasing in frequency over the last few days. Last night it was doing it 90% of the time over 7 hours.
Pump is 3 months old, if I set the head to 2M the sound quietens down, I believe that's only due to the rotations being less.
Noise "blip" can always be heard when it first spools up (sounds like the start of a slipping drivebelt), seems luck of the draw depending on the first spool if it will start to "grind", but over the last few days each spool is more likely to incur said "grinding"
Sounds like the propeller starting to scrape on the side or dodgy motor?
Decided to order another one to swap out, but out of interest wondered if anyone had any ideas on the fault
